Activity Forums Adobe After Effects Expressions Dynamic layer targeting
  • Dynamic layer targeting
    Posted by Ross Mcdowell on October 9, 2008 at 12:47 pm
    Hello all!
    Quick question for you guys, I am messing about with an expression…and I want to do something along the lines of the following:
    thisComp.layer(“layer[index+1]”).transform.position;
    Meaning that I want to be able to target the layer that is below the layer with the expression…how do I do this and is this even possible?
    It will make things easier for me as I can just duplicate pairs of layers and have it position itself for me…
    Ross
    Ross McDowell
    Animation Student
    Steve Bentley replied 8 years, 5 months ago 3 Members · 2 Replies
  • Eric Sanderson
    October 9, 2008 at 2:21 pm
    and are you saying that code isnt working?..if so try this…
    thisComp.layer(index+1).transform.position.
    in your ” layer(” “) ” you were telling AE to look for a layer named “layer[index+1]”, instead of telling it to look at the actual index.
  • Steve Bentley
    April 19, 2018 at 4:45 am
    I just stumbled on this and thought I would update and correct it. The syntax for the above is incorrect in both posts. It should be
    thisComp.layer(index+1).position;
