Activity Forums Adobe After Effects Expressions Dynamic Layer Control Effect
  • Dynamic Layer Control Effect
    Posted by Yaniv Cahoua on April 3, 2018 at 9:50 am
    Hi all !
    is there a way to dynamically set a layer control effect ?
    There is no stopwatch on the layer value….
    I want the layer selected in the effect to change according to other variables. (if a=1 select this layer, else select another layer).
    My goal in the end is to have a global variable that other expressions can reference to, instead of having to check in each expressions.
    thanks !
    yaniv
    http://www.yanivcahoua.com
    Kalleheikki Kannisto replied 8 years, 5 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    April 3, 2018 at 5:35 pm
    Depending on what exactly you’re trying to accomplish, you may be able to use a slider value to indicate the layer index.
    Senior Graphic Designer
