Activity › Forums › Adobe After Effects Expressions › Dynamic CSV Line Chart AE
  • Dynamic CSV Line Chart AE
    Posted by Gabriel Granda on August 25, 2021 at 11:57 am
    Hi everyone, I’m working with an expression that automatically generates a Line Chart from a CSV file.
    The expression works fine, but it always assumes the range of the data goes from zero to the maximum value.
    I would like to have control of the minimum value too, so for example if the values in the CSV file go from 215 to 645, I can just start the graph at 215 and avoid all the empty space from 0 to 215.
    The expression the line uses is:
    values = [];
    slider = thisComp.layer(“Line Controller”).effect(“End Row”)(“Slider”)-1;
    for(i=0;i<=slider;i++) {
    values.push(thisComp.layer(“subs.csv”)(“Data”)(“Outline”)(“Subs_1”)(“Subs_1 ” + i).value);
    a=Math.max.apply(null, values);
    start = thisComp.layer(“Line Controller”).effect(“Start Row”)(“Slider”);
    end = thisComp.layer(“Line Controller”).effect(“End Row”)(“Slider”);
    tanR = thisComp.layer(“Line Controller”).effect(“Tangent Radius”)(“Slider”);
    xpos = thisComp.layer(“Line Controller”).effect(“xpos”)(“Slider”);
    ypos = thisComp.layer(“Line Controller”).effect(“ypos”)(“Slider”);
    x = xpos – 960;
    y = ypos – 540;
    pts = new Array();
    inTan = new Array();
    outTan = new Array();
    Mult = thisComp.layer(“Line Controller”).effect(“Multiply Y”)(“Slider”);
    Maxi=thisComp.layer(“Line Controller”).effect(“End Row”)(“Slider”);
    for(i = start; i < end; i++) {
    ptX = x + (i*(1450/Maxi));
    ptY = y – (linear(footage(“subs.csv”).dataValue([1,i]), 0, a, 100, 700));
    pts.push([ptX,ptY]);
    inTan.push([-tanR, 0]);
    outTan.push([tanR, 0]);
    createPath(pts,inTan,outTan,false);
    Does anyone know how to address this?
    Thanks in advance for any help!
    Gab
    Gabriel Granda replied 5 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
