Activity › Forums › Apple Final Cut Pro Legacy › Dyld Error Message in FCP6; won’t open, crashes
  • Dyld Error Message in FCP6; won’t open, crashes
    Posted by Ken Gade on October 31, 2012 at 5:05 pm
    Hi Guys,
    Accidentally deleted FCP
    installed it, didn’t work
    Removed it using Industrial Revolution’s FCS Remover
    Got error message below
    There are NO permissions to throw away. I looked. There not there.
    Any suggestions?
    Process: Final Cut Pro [389]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.6 (6.0.6)
    Build Info: FCPApp-905291121~12
    Code Type: X86 (Native)
    Parent Process: launchd [120]
    Date/Time: 2012-10-31 10:10:21.549 -0500
    OS Version: Mac OS X 10.6.8 (10K549)
    Report Version: 6
    Interval Since Last Report: 35412 sec
    Crashes Since Last Report: 6
    Per-App Crashes Since Last Report: 4
    Anonymous UUID: E8E91602-6ADC-4342-96ED-A22675507FD1
    Exception Type: EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Crashed Thread: 0
    Dyld Error Message:
    Symbol not found: _kPrivateTundraFileWritingOptionsKey_DontValidateTimeCodeWhenWriting
    Referenced from: /Applications/Final Cut Pro.app/Contents/MacOS/../Frameworks/MIO.framework/Versions/A/MIO
    Expected in: /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    Thanks for your time.
    Ken Gade replied 13 years, 11 months ago 1 Member · 1 Reply
  • Ken Gade
    October 31, 2012 at 6:06 pm
    Hi Dave
    I just deleted FCP and NOT the suite. I may eventually have to try that.
