Activity › Forums › Adobe Illustrator › DWG format disappeared….
  • DWG format disappeared….
    Posted by Antonio on April 22, 2006 at 8:52 am
    Hi. a little technical problem here….After an Illustrator cs2 closing error when I click on file open there isn’t the dwg or dxf file format …
    I tried to uninstall completely and reinstall but is the same thing…
    Is there a script or something damaged that I could relaunch to reinstall the dwg format (in file/export all is ok and the dwg format is present)
    Any tips is welcome….
    Thanks a lot…
    Antonio replied 20 years, 4 months ago 1 Member · 2 Replies
  • Antonio
    April 26, 2006 at 3:20 pm
    None with the same problem?
    thx…
  • Antonio
    May 6, 2006 at 8:20 am
    I solved this strange thing….
    I installed a demo version of illustrator cs and after that the format dwg and dxf reappared in illustrator cs2 too…..this is a really strange thing…..but anyway it solved the problem….
    I hope this could be useful for anyone…..
    bye 🙂
