DVX DV tape exporting to youtube on Adobe Premiere Pro CC 2016
I recently bought a DSLR and am switching from Final Cut Pro to Adobe Premiere. I decided to convert my old tapes from my DVX and export them on Adobe to be viewed on youtube. No matter what choice in exporting I can’t get the footage to not be soft and muted. I know I can’t get it HD I just want it to look as good as if I play the tape through the TV. I can get the footage to look decent with interlaced video but I can’t remove the interlace without the quality dropping conceitedly. These are edited tapes I did on Final Cut Pro, I am just uploading the finished tapes and wanting to export them in a higher resolution then I was able to achieve.
Footage was filmed on DVX100B with advanced 24PA in the DVX widescreen format
Edited on Final Cut Pro 5.1.4
Sequence settings:
Sequence Preset DV NTSC 48 KHz – 23.98
Capture Preset: DV NTSC 48 KHz Advanced (2:3:3:2) Pulldown RemovalWhen Final Cut Prints it to tape it becomes NTSC 29.97
On Adobe if I export match source I get interlaced footage. I’ve tried in field options choosing “Always deinterlace” and “Flicker Removal” both greatly cut down on the finished videos quality. They appear to be the same quality as exporting with the “progressive” setting. Here’s what I have found to give the best with adobe when exporting
Export Media:
Format: H.264
Preset: Match Source – High bitrateVideo:
Filed Order: Progressive
Profile: High
Render at Maximum Depth
Bitrate Encoding VBR, 2 pass
Use Maximum Render Quality
Time Interpolation: Frame BendingI don’t have VBR 2 Pass set higher then the program defaults. Because a 188 MB file turns into a 3450 MB file.
I’m just looking to put these on youtube and have them not look like an awful 80s video tape. Does anyone know of a good setting using the most recent Adobe Premiere to export tapes for youtube? With the DVX I have never found a good answer.
