Activity › Forums › Panasonic Cameras › DVX-100 batteries with HVX-200?
  • DVX-100 batteries with HVX-200?
    Posted by Kevin on May 5, 2007 at 12:57 am
    Hi list, quick question as I just purchased and HVX-200 today and plan on shooting with it tomorrow. Can I use the batteries from my DVX-100 with it. So far the bigger ones I have work but a smaller one a put in (3 hours) was out afer ten minutes. Any guidance would be appreciated.
    Warmest,
    Kevin
    Tony Cope replied 19 years, 4 months ago 3 Members · 3 Replies
  • Noah Kadner
    May 5, 2007 at 2:07 am
    Sure it’s the same type of battery connection. Perhaps the smaller one is simpled tapped out from use.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Kevin
    May 5, 2007 at 2:26 am
    Cool. Thanks for posting back Noah. I tested more and they seemed fine but I didn’t want to learn the hard way in the middle of a shoot that there was some technical issue at play. Feel more comfortable now.
    Again thanks.
    Kevin
  • Tony Cope
    May 7, 2007 at 8:32 pm
    I’ve been using our HVX with the DVX batteries for 4 months now – and they work fine. You’re right – the small ones die pretty quickly, but I had just assumed the batteries were at the end of their life span (since those were the initial ones I purchased with the DVX.) One note – if you are shooting with the Firestore – get an additional battery (180m battery is really the way to go) and grab an extra firewire cable to have as backup.
    Good luck,
    Tony
