Activity Forums Apple Final Cut Pro Legacy dvdsp “sweet spot” at 6 mbps?
  • dvdsp “sweet spot” at 6 mbps?
    Posted by Pat Kingery on August 30, 2005 at 1:34 am
    according to the Lynda dvdsp3 training dvdsp3 gives better results by setting the avg Mbps to 5.5 and max to 6.5 rather than the 6.4/7.5 that compressor suggests as the default for 2 pass VBR of 60 minutes or less. Is this really the case? Anyone know why?
    do the lower bit rates give better compatibility/less playback problems?
    Pat Kingery replied 21 years ago 1 Member · 1 Reply
