  • Posted by Steve Cohen on March 12, 2007 at 11:49 pm
    I just srated getting an error when creating a DVD in DVDSP.
    I recently updated DVDSP to 4.1.2 and I believe this is the 1st DVD since doing so.
    My process is the same as always.
    Export QT from FCP
    Drag into DVDSP, make First play and set to beginning of Track 1 Chapter 1 at the end jump.
    Error is “Formating Failed. Building was not succesful see log.”
    The log is…
    Starting DVD Build CITYAMERICA…
    Compiler File Error
    Build cancelled
    Formatting finished.
    Building was not successful. See log.
    I know this should probably go in the DVDSP forum., but I seem to get quicker response in the FCP forum.
    Thanks;
    Steve Cohen
    Editor
    O2 Media Inc.
    Paul Ladd replied 19 years, 5 months ago 5 Members · 11 Replies
  • 11 Replies
  • Steve Cohen
    March 12, 2007 at 11:51 pm
    1 addition.
    I did not update FCP to 5.1.4 yet because I want to stay equal to my office and they are still at 5.1.2.
    [Steve C] “I just srated getting an error when creating a DVD in DVDSP.
    Export QT from FCP
    The log is…
    Compiler File Error
    Build cancelled
    Thanks;”
    Steve Cohen
    Editor
    O2 Media Inc.
  • Chris Tompkins
    March 12, 2007 at 11:56 pm
    Build to disc first. Then take your TS folders and burn them onto disc w/ Toast or any Disc burning software
  • Nate
    March 13, 2007 at 12:06 am
    Steve, I was getting the same errors… with a 2 hour movie… I thought it was the length. I still do not understand where the problem was. It would always lock up on a frame and just keep going. I got everything to work by going thru Compressor first and then to DVDSP#4. But it would only complete the process if my source drive and target drive where 2 different drives. I have a Medea raid and you would think that would be fast enough to be the source and the target.
  • Steve Cohen
    March 13, 2007 at 12:10 am
    I have a G-Raid also and I’ve done this before with no problem.
    I’m trying Compressor now, but have never done it that way, so I’m not sure of the process.
    Steve Cohen
    Editor
    O2 Media Inc.
  • 13 Create COW Profile Image
    13
    March 13, 2007 at 12:18 am
    This is the Final Cut Pro forum this question should be posted on the DVD Studio Pro Forum
  • Nate
    March 13, 2007 at 12:47 am
    Yeh you are probably right a cross post maybe….
    But I tried the DVD SP forum a couple weeks ago and the great gurrus over there rarely show for work..
    So the guy has a problem, just like I did,,, and with no help the client will walk ,, understand
    so chill dude..
    13
    March 13, 2007 at 12:57 am
    “so chill dude..”
    All I was doing was letting him know that he posted in the wrong place, besides the DVD SP forum looks like it gets plenty of use to me, I check there just as often as I do the FCP forum.
  • Steve Cohen
    March 13, 2007 at 1:11 am
    I know this is a FCP forum and it should have gone in the DVDSP forum.
    If you read my first post I said…
    “I know this should probably go in the DVDSP forum., but I seem to get quicker response in the FCP forum.”
    I have responded to many post that were in the wrong forum, because I could help the person.
    It shouldn’t make a difference where it is posted. If you can help someone help them, if not don’t say anything.
    Steve Cohen
    Editor
    O2 Media Inc.
  • Nate
    March 13, 2007 at 4:22 am
    AMEN
  • Steve Cohen
    March 13, 2007 at 12:08 pm
    Hey I don’t like having to say stuff like that, but I’m sick of people putting their useless comments here.
    Like wrong forum.
    Read the manual or other stuff.
    You could answer the peorsons question (assuming you know the answer) and then add “This information could be found on page xxx of the FCP manual.; or something like that.
    By the way Chris’ suggestion of “Build to disc first. Then take your TS folders and burn them onto disc w/ Toast or any Disc burning software” worked just fine for the mean time. I would still like to fix the issue though.
    Thanks again;
    Steve Cohen
    Editor
    O2 Media Inc.
