Activity › Forums › Apple Final Cut Pro Legacy › DVDSP Error
Paul Ladd
March 28, 2007 at 8:47 pmDon’t know if anybody is still reading this thread or not, but I expereienced the same problem recently. It happened when I upgraded to 4.1.2. Whenever I tried to burn my disc I would get the “compiler file error” see log. I tried to re-install DVDSP and still had the same problem. I was able to correct this problem by building the disc first (does the muxing and compiling and creates VIDEO and AUDIO TS folders, which I never had to do in previous versions) and then burning it from DVDSP works just fine. When I first learned DVDSP years ago i was taught to use this method, but over the years I guess I got into a habit of cutting out the build step (which worked fine until the upgrade).
I hope this helps!
