Activity Forums DVD Authoring DVDSP DVD plays in my MAC but not in a DVD Player
  • DVDSP DVD plays in my MAC but not in a DVD Player
    Posted by Phil Lebeau on April 7, 2010 at 4:18 pm
    Don’t know where to start but I created a DVDSP project with a main menu and it has lots of other videos and menus added to it.
    Once I burned it to a DVD – it will play on my MAC but will not play in my DVD player. Everything simulates fine. As far as I know the dvd is a DVD-r.
    I have the menu as first play…
    When you put the dvd in a player – it loads then stops.
    It is a SD project but my video is 960×540 – I didnt shoot it – the video was given to me and I had to make a dvd out of it.
    I also had to convert the video to a .mov file using Stream Clip. But even if the video was a problem, why doesn’t my menu come up first?
    Thanks for any help – this is a work project and it will be duplicated.
    Phil Lebeau replied 16 years, 5 months ago 2 Members · 3 Replies
  • Phil Lebeau
    April 7, 2010 at 4:25 pm
    How can I tell if my project is SD or HD and how do I make sure that my new project is in SD and not in HD?
  • Michael Sacci
    Most likely you have created an HD DVD disc, even if your assets are SD, it will not work.
    If is is a HD DVD you will have to reauthor the disc as a SD DVD.
  • Phil Lebeau
    April 7, 2010 at 5:19 pm
    I figured it out – Crazy HD DVD button was pressed – Arg – back to the drawing board.
