Activity Forums VEGAS Pro DVDA re – render
  • DVDA re – render
    Posted by Vegasarian on May 9, 2006 at 8:05 am
    I rendered a 1 and a half hour movie (4 video tracks, 2 audio lots of effects) to MPEG2 from Vegas 6.0d. Took about 5 hours. No problem there. I’m trying to get away from TPMGEnc and decided to use architect 3.0c. Its now currently re – rendering the MPEG2 file, taking another 5 hours.Is this normal? TPMGEnc made this DVD from the MPEG2 file in under an hour. Presumably I’m also going to lose quality in the re – render.
    Mike Kujbida replied 20 years, 4 months ago 2 Members · 2 Replies
  • Mike Kujbida
    May 9, 2006 at 10:53 am
    With a video that long, you need to adjust the MPEG bit rate in Vegas using a bit rate calculator. By my calculations, you’d set it to a CBR of 6400 or a VBR of 8000, 6400 & 3800. This assumes you’re rendering the audio as AC3.
  • Mike Kujbida
    May 9, 2006 at 10:55 am
    The number of FX will also slow the initial render down too.
    However, if you choose the right render settings, DVDA will never have to re-render.
