Activity Forums VEGAS Pro DVDA menu audio problem/help
  • DVDA menu audio problem/help
    Posted by Woodman on November 30, 2006 at 3:11 pm
    I continue to have audio problems with DVDA 3.0c build 133. I preview all menues and the audio is perfect. When I burn the dvd, I end up with all video correct, but there is a lag of approximately 1.2 seconds in the audio for all menues before it starts. Once it starts, it plays perfectly. I don’t understand why there is this 1 sec delay. And when I say delay, the audio is not behind by 1 sec, it just starts playing at the 1.2 sec. time mark and is where it should be-Just missing the first second or so of the audio. The actual contnet audio plays exactly as it should. I have redone this dvd several times, always with similar problems. Even started from a new project and rebuilt from scratch. Any help would be greatly appreciated.
    Tattoo replied 19 years, 9 months ago 3 Members · 3 Replies
  • Gary Kleiner
    December 1, 2006 at 3:01 am
    The completed disc should be just like the preview. Not sure what’s going on there.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Woodman
    December 1, 2006 at 3:31 am
    is it possible to have something wrong with the software? should I reinstall it? This is the first time I have ever had this problem and I have made many DVDs.
  • Tattoo
    December 18, 2006 at 12:08 am
    How long is the clip you are trying to render to DVD? Sometimes if they are very long, the audio will get out of synch…try splitting the clips into 5 min or less each, then add them to be rendered as a DVD.
