Activity Forums VEGAS Pro DVDA “buttons”: One size
  • DVDA “buttons”: One size
    Posted by John Gregoriades on January 13, 2009 at 2:57 pm
    Hi again,
    Hope the holidays went well for you.
    Playing with DVDA 4. A Menu-based project. I use several (as many as 10 pre-rendered segments, each with its own “button,” etc. I know how to select the shape of the buttons’ frame from DVDA’s collection, etc. and moving them to the selected locations, and resizing them to fit my liking.
    What I can’t figure out is how to get all the several “buttons” to be identical in size, on-screen. So far I can only do it by “eyeball.”
    I’m sure there is an easy way to do this, so I could use some help. (I’m guessing holding down some key while adjusting size???)
    Thank you,
    John
    John Gregoriades replied 17 years, 7 months ago 3 Members · 4 Replies
  • Joe Mantaratz
    January 13, 2009 at 3:41 pm
    The easiest way to do this is to simply copy the empty button and then paste where you’d like. Otherwise you can select the button and it’s properties window will display the area to adjust the number manually. You would have to write those numbers for X and Y size down and then input them to each of your other buttons. That’s the long way. Hope this helps.
    Joe
  • John Rofrano
    January 13, 2009 at 4:42 pm
    The icon panel just to the left of the main windows has options for Make Same Width and Make Same Height. Just select multiple buttons and use those to make them all the same.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joe Mantaratz
    January 13, 2009 at 4:54 pm
    Never used that function…thanks John…
  • John Gregoriades
    January 13, 2009 at 7:08 pm
    Many thanks to both you gentlemen, for your quick responses.
    John
    John23GR
