DVDA and UDF version for a BD-R
I am ready to burn a BD-R disc that was authored in DVDA. I used DVDA to create an iso image file. I now want to burn it to the BD-R. What UDF version is being used by DVDA for the bluray disc? I know in Nero if you burn from a folder structure it will let you select the UDF. The default UDF in Nero is 1.1 but if you select 2.5 or 2.6 in Nero it will play in more Bluray players and also the PS3. I want to make sure the disc burned from DVDA will play in PS3 but can’t find how to control the UDF version.
Anyone know the version?
