Activity Forums VEGAS Pro DVDA 5.2 Won’t Burn
  • DVDA 5.2 Won’t Burn
    Posted by Ken Bennett on October 13, 2011 at 6:14 pm
    Just ran into a wall. DVDA 5.2 will not allow me past the Optimize to Fit to Disk screen. When I get to the Select Burn Parameters everything is ghosted out except for Back! I’ve got it set to fit disk at 92% (program is 82 mins + menus). First time this has happened. I’m letting DVDA do the encoding. What’s wrong?
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Paul Atkin replied 14 years, 10 months ago 2 Members · 1 Reply
  • Paul Atkin
    November 14, 2011 at 8:06 am
    I have a slightly different issue. I could compile a project in DVDA with no problems and create the ISO file but DVDA 5.2 gets stuck between burning the lead-in and start of proper track burning (which destroys a disk).
    The only solution I found so far is to use third party software to burn the ISO file to disk.
    The same project (DVD version) compiled and burned no problem using an internal DVD drive.
