Activity › Forums › VEGAS Pro › DVDA 4.0 Problem with subtitles
  • DVDA 4.0 Problem with subtitles
    Posted by Alejandro Torres on September 8, 2007 at 3:55 am
    Hello everyone, I know you’ve probably heard this problem a lot, but I am subtitling a video in both spanish and portuguese. I’ve added the two tracks of subtitles and a menu at the beginning that enables you to chose between no subtitles (action in subtitles set to off), spanish and portuguese.
    When I am about to burn the DVD there are some error messages that state that the subtitles are to complex due to an horizontal line. This error is displayed also in the no subtitles track.
    I checked the help and it says that I should turn outline off but my client wont take them that way.
    What should I do, is there an easy solution I am missing; I don’t want to rewrite and reaccommodate the subtitles again. I don’t know if I can export them (in the worst of the cases) to vegas and render them along with the video, but I would need 3 copies of the video, making the DVD bigger and killing the subtitle button function in the remote.
    Please have a look at my issue, any help or ideas would be appreciated. Deadline is tomorrow (sunday) night Pacific Time.
    Thanks in advance
    Alejandro
    Alejandro Torres replied 19 years ago 2 Members · 2 Replies
  • Edward Troxel
    September 8, 2007 at 8:25 pm
    The answer is to make them “less complex” this often means SHORTER. It would be nice if it pinpointed exactly which one(s) where too complex.
    Edward Troxel
    JETDV Scripts
  • Alejandro Torres
    September 8, 2007 at 9:23 pm
    Thanks for your response. What I did was disabling the outline and setting the background color to transparent.
    It partially worked because the subtitles without outline look worse than the normal ones.
    Regards
    Alejandro
