Activity Forums VEGAS Pro DVDA 2.0 how to loop menu backgrounds?
  • DVDA 2.0 how to loop menu backgrounds?
    Posted by Larry Watts on April 27, 2005 at 3:21 pm
    I have a 30 sec mpg to use as a backround for the main menu.
    I thought in DVDA 1.0 I could loop the file. I can’t find a way to loop it in 2.0
    (maybe I am wrong about 1.0.)
    Can you set in and out points for a menu background mpg file?
    Can you adjust the volume on an audio file background?
    Version 2 doesn’t seem as intuitve as version 1.0 was, but I do see more features!
    Larry
    LSW
    Gary Kleiner replied 21 years, 4 months ago 2 Members · 1 Reply
  • Gary Kleiner
    April 27, 2005 at 3:47 pm
    [Larry Watts] “I have a 30 sec mpg to use as a backround for the main menu.
    Can you adjust the volume on an audio file background? “
    Loop the backgound by going to Menu Page Properties>End Action>Command>Loop
    No, you cannot set the in/out points on the menu background media. Render it as you need it in Vegas.
    Same with audio, render the length and volume in Vegas.
    Gary Kleiner
    Vegas Training and Tools.com
