Activity Forums Adobe Premiere Pro DV/D1 Pal 720×576 export (a little explanation needed)
  • DV/D1 Pal 720×576 export (a little explanation needed)
    Posted by Vaggelis Valassopoulos on December 29, 2017 at 1:08 am
    Hi to the forum, and merry Christmas,
    This is my third post here and i am so glad that always i got all the info i was looking for.
    To just dive right in,
    I decided to capture VHS tapes, with virtualdub and after a lot of search i had done a pretty good job with filters codecs and etc.
    I only have a question when it comes to premiere trim and export sequence part.
    I figured out that i have two option in virtualdub for capture pin resolution.
    One is 640×480 or 720×576. I will explain in a little what i mean.
    I use TU-R422 BT.601 (i think smrhing like that) loseless codec for compression and i get a 10gb file for a 45′ tape.
    The only thing i want to figure out is the res and the PAR.
    When i select the 640×480 res the video output is 4:3 and recognized as Square pixels by premiere and it doesnt look transformed to me, but with 720×576 I get a little more content and a little more bars (its fine i will crop them afterwards) and the PAR is DV/D1 PAL 1.0940 and when i playbacked its 5:4 and a little stretched and transformed.
    The signal is PAL_B and i assume that with 640×480 the virtualdub does a resize by itself.
    to sumup i want to record in DV/D1 PAL 1.0940 and right in premiere to trim and export it as X*576 or 640*480 in 1:1 PAR Square pixels!
    How can i achieve this ?
    Thank you a lot in advance,
    Vaggos Val
    Vaggelis Valassopoulos replied 8 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
