Activity › Forums › Apple Final Cut Pro Legacy › DVD to Mpeg Stream Clip to Final Cut
  • DVD to Mpeg Stream Clip to Final Cut
    Posted by Chuska Esteban on June 20, 2011 at 1:20 pm
    Hello:
    I have doubts about a project I have to do.
    It´s a video that has to be projected on big screen (small cinema).
    The material that I have are DVDs and photos. I wonder two questions.
    What is the best setting to convert the DVD with Mpeg Stream Clip to work with Final?
    I am in Europe so the DVDs are PAL. Apple Pro 4:2:2 8 bits Uncompresed or Apple Pro Res 4:2:2 HQ
    What is the best sequence settings to work in Final with that material?
    Then I guest I have to use the same settings of the quicktime created.
    I don´t know how I will give the master, probably a quicktime that they can send from the computer to the projector.
    Thank you so much, and have a nice day.
    Steve Eisen replied 15 years, 3 months ago 2 Members · 1 Reply
  • Steve Eisen
    June 20, 2011 at 1:37 pm
    ProRes or ProRes LT if you have FCP7. Uncompressed and ProRes HQ will not improve your footage. It will just give you enormous file sizes.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
