Activity › Forums › Apple Final Cut Pro Legacy › DVD to dv conversion
  • Bouncing Account needs new email address
    February 10, 2007 at 3:32 pm
    Here are 3 popular rippers.
    https://www.dvdxdv.com/
    https://www.miraizon.com/products/products.html
    Mpeg SlipStream is very popular -found here-
    https://www.squared5.com/
  • Jim Finn
    February 10, 2007 at 5:02 pm
    the mpeg streamclip is telling me i need to buy something from apple to run it from a dvd and the others cost between 80 and 120 dollars. One thing i tried was to compress is to mpeg4 in handbrake and then bring it to dv in streamclip but i imagine i’m losing quality with that. haven’t seen in on a tv though.
    https://www.interkosmosmovie.com
  • Debe
    February 10, 2007 at 5:13 pm
    That’s odd. What does it say you need to buy from Apple?
    I’ve installed it on 4 machines, and it’s never told me I needed to buy something.
    debe
  • Jim Finn
    February 10, 2007 at 5:24 pm
    I go into the video TS folder and try to open the vts fiels and i get the Quicktime 6 MPEG 2 playback component is not installed
    You will miss the two most important features of MPEG Streamclip:
    – you won’t be able to play MPEG-2 files and transport streams;
    – you won’t be able to convert MPEG-2 files and transport streams to QuickTime, DV, AVI.
    However, all other features are always available, including playback and conversion of MPEG-1 to QuickTime, DV, AVI, demuxing of MPEG-1 and MPEG-2, AC3 decoding, and conversion from transport streams to MPEG files (useful if you have Toast 6).
    MPEG Streamclip is free of charge but the MPEG-2 Playback Component has a small price (around $20/
  • Jim Finn
    February 10, 2007 at 5:25 pm
    Are you able to get dvd files into final cut with streamclip?
  • Tom Wolsky
    Are you using Final Cut Pro or Final Cut Express? You need the MPEG-2 playback component.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Jim Finn
    February 10, 2007 at 5:26 pm
    I have FCP 5.1 not express. Shouldn’t that come with it?
  • Debe
    February 10, 2007 at 5:29 pm
    If you have FCP, then you have QuickTime Pro. QuickTIme Pro installs when you install FCP.
    Have you actually treid to install and run it MPEG Streamclip? You might not have a problem at all, if your QuickTime Pro is insalled properly, which it should be if you used the Installer, then it should just work.
    debe
  • Debe
    February 10, 2007 at 5:31 pm
    I just re-read your post. What version of FCP are you running? You may just need an older version of MPEG Streamclip.
    debe
  • Tom Wolsky
    Sounds like the installation wasn’t done correctly. If you correctly installed the Studio suite you should have it.
    All the best,
    Tom
