Activity › Forums › Apple Final Cut Pro Legacy › DVD Text Pixelation
DVD Text Pixelation
Posted by Brad Champagne on April 8, 2012 at 11:57 amI have a ProRes 422-HQ video that I’m outputting from FCP with current settings. When I apply the MPEG-2 DVD settings to the video in Compressor the text comes out badly pixelated. What’s happening?
I can give more information as needed. Thanks!
Joseph Hung replied 14 years, 4 months ago 4 Members · 4 Replies -
Jerry Hofmann
April 8, 2012 at 2:43 pmWhat was the original shooting format, and how did you get it to ProRes if indeed that was the workflow… or did you record directly to ProRes from the get go?
I’d certainly try a CBR at about 8 Kbps if your program is under an hour.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Brad Champagne
April 8, 2012 at 7:00 pmWe shot on the Canon 7D & 5D. We transfered the footage to Prores from the original H264 camera files using the Canon log and transfer plugin. It’s a short film, about 15 minutes so yea it’s definitely under an hour. What’s a CBR?
Thanks so much for the response!
Rob Grauert
April 9, 2012 at 1:51 pmCBR is Contant Bit Rate, as opposed to VBR which is Variable Bit Rate.
CBR @ 8Kbps might help, but I’m also curious what your text looks like. If it’s small and thin, then yea, it will look like crap when converted to SD.
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com -
Joseph Hung
April 9, 2012 at 10:21 pmMore info would be helpful too. Like how the text was made? is it scrolling or stills? And to be clear you’re downrezzing from HD to SD?
http://www.tulpapictures.com
Twitter: @tulpapictures
Facebook: http://www.facebook.com/tulpapicturesMac 2.66 GHz Quad Intel Xeon
OSX 10.6.8
FCS2
CS5
8GB RAM
ProAvio 8TB RAID 5 Dual Mini-SAS
Blackmagic Intensity Pro
ATI Radeon X1900
RocketRAID 4322 via dual MiniSAS
Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
