Activity Forums Broadcasting DVD source okay for broadcast?
  • DVD source okay for broadcast?
    Posted by Susi Mason on December 26, 2009 at 10:21 pm
    I’m working on a documentary for broadcast that is drawing from a variety of source material, some of which I’m afraid is only available to us on DVD. Will DVD quality be sufficient to meet broadcast specs? How can I convert the DVD video to be the best possible for use in a Apple prores edit on FCP? Thanks.
    Tyler Ries replied 16 years, 8 months ago 3 Members · 2 Replies
  • Bob Zelin
    December 27, 2009 at 7:12 pm
    that is not up to the people on this list. Every station has different delivery requirements. Of course, you can just playout the DVD video into your show (rip the video, or digitize it in with an AJA or Blackmagic card at ProRes422HQ), and don’t tell anyone.
    When you work in broadcast, there are broadcast delivery requirements, and every station is different. Some accept DVD and VHS, others are on the other side of the spectrum, and will only accept a Sony HDCam SR master. Have you called your station ?
    bobZelin
  • Tyler Ries
    December 28, 2009 at 4:09 am
    You know that DVD’s do not have the same quality as a majority of the professional formats available, or you would not be asking the question. Sure, DVD is not the best quality, but if that’s all you have to work with then it will have to do. Some DVD’s are better than others, a professionally made disc with proper compression will look better than something made with a home DVD recorder, so you best bet is to choose your sources carefully.
    If you want a program to copy the contents of a DVD onto you computer to be used as editing material, this is a favorite of mine. Squared 5 makes a great freeware program called MPEG Streamclip (https://www.squared5.com/). This program works just like the capture window in FCP, with the ability to set in/out points. The program uses any of the codecs you already have installed in your system (which should give you plenty of good options if you do have FCP installed). Once these files are created, they can be imported and used normally. The compression codec that you use is important, I have seen a noticeable difference between exporting in DV50, ProRes and 8-Bit Uncompressed, all from the same source DVD. Do some tests to find the codec that works best.
