Activity Forums VEGAS Pro DVD render problem
  • DVD render problem
    Posted by Bob Mark on September 28, 2012 at 7:45 pm
    I just downloaded the Vega 11 build 701 64 bit and tried to burn a DVD from the timeline. When playing the burned disk it starts in the middle, not at the beginning. Any idea what happened?
    Thanks.
    Bob
    Bob Mark replied 13 years, 12 months ago 2 Members · 2 Replies
  • Andrew Lenczycki
    October 1, 2012 at 2:23 pm
    Did you have the Render Loop Region Only checkbox checked in the render dialog box? If this was checked and you had only a portion of your timeline in the blue Loop Region, then it will only render that portion of your project.
    Andrew Lenczycki
  • Bob Mark
    October 1, 2012 at 3:37 pm
    The render DVD dialog box does not have that option. If you mean the render as dialog box, then, no loop region only was not selected. I have done this successfully before. I wonder if it might have something to do with build 701? Thank you.
    Bob
