Activity Forums Apple Final Cut Pro Legacy DVD quality from FCP
  • DVD quality from FCP
    Posted by Coulter Mitchell on September 8, 2007 at 4:28 pm
    I made a quicktime movie from FCP, and the footage is 720p. I put a deinterlacer on all the footage and made a self contained quicktime movie, and when I play the movie it looks beautiful. But when I make a DVD of it in iDVD, all the edges look pixelated and straight lines become jagged lines; smooth edges become ragged. How can I fix this? Help?!?
    13 replied 19 years ago 6 Members · 19 Replies
  • 19 Replies
  • Tom Wolsky
    September 8, 2007 at 4:36 pm
    720p has no interlacing. Why did you deinterlace it? iDVD always interlaces DVD material for standard definition 720×480 output.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • John Pale
    September 8, 2007 at 4:43 pm
    [Atari Norris] “I made a quicktime movie from FCP, and the footage is 720p. I put a deinterlacer on all the footage and made a self contained quicktime movie, and when I play the movie it looks beautiful.”
    Why in the world would you put a deinterlacer on progressive footage? It is not interlaced to begin with.
    I’m not sure if iDVD knows to handle progressive footage. It’s probably converting it to 480i when it does the MPEG encode.
  • David Roth weiss
    September 8, 2007 at 4:46 pm
    [Atari Norris] “I made a quicktime movie from FCP, and the footage is 720p. But when I make a DVD of it in iDVD, all the edges look pixelated and straight lines become jagged lines; smooth edges become ragged. How can I fix this? Help?!?”
    Its hard to understand why you would bother to shoot 720p if you’re going to encode your DVD using iDVD. You might at well shoot on VHS.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Tom Wolsky
    September 8, 2007 at 4:48 pm
    I’m not entirely sure DVDSP knows how to do it either.
    All the best,
    Tom
  • John Pale
    September 8, 2007 at 4:54 pm
    [Tom Wolsky] “I’m not entirely sure DVDSP knows how to do it either.”
    You can make 24p SD DVD’s with DVD Studio Pro.
  • Coulter Mitchell
    September 8, 2007 at 5:02 pm
    Thanks for responding. So you’re suggestion then is to not deinterlace it? Is there is no way to print out a 720p from iDVD? The only reason I put a deinteralacer on it was because it looked pixelated and low-quality, and I was just experimenting to make it look better. If there isn’t a way to print it out from iDVD, what kind of software do you recommend that is either cheap or free? Thanks!
  • David Roth weiss
    September 8, 2007 at 5:21 pm
    If you have the Final Cut Studio then you have Compressor and DVDSP.
    BTW, you really should update your profile with info about what you’ve got so that people can better help you.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Tom Wolsky
    September 8, 2007 at 5:23 pm
    Indeed. Just it’s converting of interlacing material to deinterlaced I’m not so happy with. Perhaps I haven’t found the magic settings to this well.
    All the best,
    Tom
  • Tom Wolsky
    All the best,
    Tom
  • Tom Wolsky
    September 8, 2007 at 5:27 pm
    You’re talking about outputting a high definition DVD. There is no cheap software or hardware to do this. iDVD only does interlaced standard definition. Depending on the length of your material you can get pretty good quality with it, especially in the current version. Are you looking at it on a set-top box or a computer? The computer will show interlacing.
    All the best,
    Tom
