Activity Forums VEGAS Pro DVD Quality DVD Architect 3- How can it be improved?
  • DVD Quality DVD Architect 3- How can it be improved?
    Posted by Maurom on June 2, 2006 at 1:27 am
    I compile my movies which may be only 1-2 gigs and as an MPEG-2 file is really clear, but when I use DVD Architect to create the DVD and then play it back I find that the image quality is far less. From the area you can actually see burnt onto the DVD it appears to be much more than if just burnt as an MPEG-2 file. When I use SONIC DVDLite however to create my DVD the picture quality is perfect – is there a setting that I need to use in DVD Architect to ensure it only uses the orignal file size without expanding it to nearly the full size of DVD disk? Thanks
    MMM
    Maurom replied 20 years, 3 months ago 2 Members · 2 Replies
  • Edward Troxel
    June 2, 2006 at 1:39 pm
    Is DVD A recompressing the file? It shouldn’t with a DVD valid file. Which preset did you use to create the file? Did you go to the Optimize screen (sometimes doing so forces DVD A to recompress).
    Using the DVD A presets in Vegas, DVD A has not recompressed my files and the ending DVD looks great.
    Edward Troxel
    JETDV Scripts
  • Maurom
    June 7, 2006 at 11:43 pm
    many thanks jedidtv,
    I’ll re-check my settings and then re-post what I have discovered
    MMM
