Activity Forums Adobe Encore DVD dvd project out of space – where/how best to compress?
  • dvd project out of space – where/how best to compress?
    Posted by Ktpmm5 on February 12, 2007 at 10:48 pm
    I have 10 avi files captured via Premiere, straight from my dv camcorder. I bring them into Encore, add 2 menus, and try to put them only a dual-layer dvd. No luck – they total 10gb. Is there a way to compress them in Encore?
    I’ve also tried outputting them various ways thru Premiere, but can’t seem to find a way that compresses them into smaller files (tried microsoft avi, microsoft dv quicktime with sorenson compression, etc). Does anyone have any other ideas? Thanks-
    Ktpmm5 replied 19 years, 6 months ago 3 Members · 5 Replies
  • Joe Bowden
    February 12, 2007 at 11:26 pm
    What’s the total duration of your video files?
  • Ktpmm5
    February 12, 2007 at 11:50 pm
    About 9-10 hours of total time-
  • Joe Bowden
    February 13, 2007 at 12:40 am
    What you’re trying to do is somewhat impractical.
    With 9 hours of video, your average bitrate would be about 1.8 Mbps, which will yield very poor visual quality. If you used two dual-layer discs, your average bit rate would double to 3.6 Mbps, which is still pretty low. But with two discs, you could decide which videos to allow a higher bitrate, and which to assign a lower one – that’s not an option you have a single dual-layer disc, due to the lack of disc space.
    Consider putting it on two or more dual-layer discs.
  • Mylenium
    February 13, 2007 at 11:09 am
    [ktpmm5] “I’ve also tried outputting them various ways thru Premiere, but can’t seem to find a way that compresses them into smaller files (tried microsoft avi, microsoft dv quicktime with sorenson compression, etc). Does anyone have any other ideas? Thanks-“
    That kind of fiddling is not going to do any good. DVD (Video) is always MPEG-II, you cannot change that. Like Joe said, your options are limited and it would be best to span the entire stuff across multiple discs.
    Mylenium
    [Pour Myl
  • Ktpmm5
    February 13, 2007 at 2:24 pm
    That makes perfect sense – thanks for explaining it to me. I’ve contacted the client and let him know what his options are. Thanks again!
