Activity › Forums › VEGAS Pro › DVD playback Flicker on TV (but not original export from AE7 as MPEG2-DVD)
  • DVD playback Flicker on TV (but not original export from AE7 as MPEG2-DVD)
    Posted by Jay Ingles on January 17, 2007 at 7:51 pm
    heres the problem. I’ve created a simple slideshow with fades (no zooms) in after effects 7 and exported as MPEG-2 DVD. brought this into DVD Architect 3, added a menu and a simple play track button. It encodes in no time and burns no problems. During playback on an interlaced TV the image flickers in the high-contrast/detailed parts of the image.
    i’ve tried a couple things and can’t figure it out. i’ve read another post on this site but it wasn’t resolved. any help is appreciated.
    all the settings i used to export from AE7 are below.
    thanks.
    /josh
    heres what i’ve exported from after effects as:
    DISK 1:
    Render Settings:
    quality best
    res full
    size 720×480
    field render off
    frame rate: 29.97
    pulldown off
    Output Module:
    Format: MPEG2-DVD
    Final Size: 720×480
    DISK 2 (only changed lower field first):
    Render Settings:
    quality best
    res full
    size 720×480
    field render Lower Field First
    frame rate: 29.97
    pulldown off
    Output Module:
    Format: MPEG2-DVD
    Final Size: 720×480
    DISK 3 (only changed upper field first):
    Render Settings:
    quality best
    res full
    size 720×480
    field render Upper Field First
    frame rate: 29.97
    pulldown off
    Output Module:
    Format: MPEG2-DVD
    Final Size: 720×480
    DISK 4:
    exported field render off
    Format: MicrosoftDV (keyframes every 1 frame, spatial qual 100)
    (note: never actually burned this b/c i watched the playback and there were other problems that played back poorly)
    Gary Kleiner replied 19 years, 8 months ago 2 Members · 1 Reply
  • Gary Kleiner
    January 19, 2007 at 1:13 am
    Perhaps field render should be on.
    Also, it’s a fact of life that when you take a high detail image, you can get interlace flicker on fine detail such as thin lines, and the only way to prevent that is to “dumb down” the image with a touch of blur.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
