Activity Forums Adobe Encore DVD DVD not recognized by duplicator
  • DVD not recognized by duplicator
    Posted by Brian Holson on May 13, 2009 at 4:23 pm
    This was my first project with Encore and everything went smoothly until I burned the disc and tried to put it in a duplicator to make several copies. I did make sure the copy protection was off. I checked the project and no issues came up.
    The DVD plays fine in a DVD player, buttons work, etc., but the duplicator doesn’t recognize it as a valid disc. Is Encore not “finalizing” the disc when it’s finished or is is somthing else that’s keeping it from being recognized? The duplicator is a Primera Bravo Pro.
    Jon Geddes replied 17 years, 3 months ago 3 Members · 14 Replies
  • 14 Replies
  • Joe Bowden
    May 13, 2009 at 5:02 pm
    How much content is on the disc?
  • Brian Holson
    May 13, 2009 at 5:27 pm
    Under an hour. I transcoded it at 4mb VBR 2 pass.
  • Brian Holson
    May 13, 2009 at 6:50 pm
    2.4GB
  • Joe Bowden
    May 13, 2009 at 7:00 pm
    Sorry I wasn’t clearer, I meant how much data is written on the disc?
  • Joe Bowden
    May 13, 2009 at 7:26 pm
    That should be enough data (I’ve heard reports that this happens when data is 1 GB or less).
    Which disc format did you burn to?
  • Brian Holson
    May 13, 2009 at 7:28 pm
    Taiyo Yuden DVD-R 16X
  • Joe Bowden
    May 13, 2009 at 8:38 pm
    That’s fine quality. I’m guessing that somehow it’s not being properly closed by Encore.
    There are a couple of avenues you may want to try – one would be to build a DVD folder and use ImgBurn (freeware) to burn it using the same brand of DVD-R and try this with your duplicator. Another would be to try burning a DVD+R instead, and see if that works on the duplicator’s system.
  • Joe Bowden
    May 13, 2009 at 8:48 pm
    Use Encore to build a DVD folder (you can do this in the Build panel), and then use the folder as the source for ImgBurn.
  • Brian Holson
    May 13, 2009 at 8:53 pm
    So do I still use Encore to set up the disc and export the file to ImgBurn?
  • Brian Holson
    May 13, 2009 at 9:05 pm
    I’ll give it a shot. Thanks Joe, you’ve been a big help again!!
