Activity › Forums › Compression Techniques › DVD movies are very fuzzy after burning a made video
  • DVD movies are very fuzzy after burning a made video
    Posted by Anthony Kobrowisky on November 14, 2012 at 10:36 am
    Hi there,
    I am looking for some urgent needed help with regards to my DVDs that i have been making. I edit in Final cut X , send to compressor 4 0 3 and the videos are extremely bad quality after i burn them to a DVD. My settings are as follows:
    1920 X 1080 25p HD on FCP X
    on compressor my custom settings are
    Description: MPEG-2 elementary stream for DVD Authoring
    File Extension: m2v
    Estimated size: 2.79 GB/hour of source
    Type: MPEG-2 video elementary stream
    Usage:SD DVD
    Video Encoder
    Width and Height: Automatic
    Selected: 720 x 576
    Pixel aspect ratio: PAL CCIR 601 (16:9)
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Off
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic:
    Selected Progressive
    Average bit rate: 6.2 (Mbps)
    1 Pass VBR enabled
    Maximum bit rate: 7.8 (Mbps)
    Best motion estimation
    Closed GOP Size: 1/2 second, Structure: IBBP
    DVD Studio Pro meta-data enabled
    Using princo 16X dvd disks
    When i play the video through my Mac book, the quality is great. Just after the burn makes it look terrible. I Also need help fast as these vids are for customers.
    Im new to this so please give reply with step by step instructions if you have any!
    Thanks you!!!
    Ant
    David Eaks replied 13 years, 10 months ago 2 Members · 1 Reply
  • David Eaks
    November 14, 2012 at 12:43 pm
    Try exporting your HD project with current settings, then bring that file into a new project. Change this new project’s settings to SD then export the timeline. Bring the exported SD file into compressor and burn same as before.
    Or just duplicate the HD project, change the duplicate project to SD then export and burn.
    It should be a little better, the image will be soft especially on an HDTV but should be pretty clean and free of compression artifacts and “blockiness”. The DVD should look pretty darn good when viewed on and old 4:3 SD CRT TV. The thing is, a DVD is never going to look as good as your HD project. I’ve found the above method to be comparable to hardware downscaling to SD with either my Matrox MXO2 LE or AJA Ki Pro before compressing and burning the DVD.
    The real solution is to burn a Blu-ray. Blu-ray burners are cheap, but the encode time is long (Matrox MAX takes care of that). Your customers will need a Blu-ray player and an HDTV to really appreciate your original HD quality. Or upload HD to YouTube or give them an HD digital file to play on their computer or iPhone/iPad etc. Some HDTV’s and Blu-ray players even have USB ports or SD Card readers and can play HD video from a USB drive or SD card.
    Personally, I’m anxious for the DVD format to die out, it is obsolete. Unfortunately, it’s still in wide use and we all have to deal with it.
