Activity Forums VEGAS Pro DVD Motion Menu Crashes Program
  • DVD Motion Menu Crashes Program
    Posted by Gerald Stokes on July 2, 2008 at 4:02 am
    Yep another problem…
    I created a motion main menu by animating some generated media in vegas, Moving clouds to be exact. I then added audio, all fine and well. When I choose to have the menu loop with music, it comes up with an error message and the entire program crashes. It happens so fast I can’t even click on the error details and I loose everything. I tried many things to see what was causing this. Different audio file types. Shorter menu time etc. I found that when I set the main menu to hold after the 2min, no crash? I really wanted to have the motion menu and it’s music loop over and over again. Any reason for this to happen? I can have the Motion Video loop as long as there is no music.
    Using DVD-A 4.5A, and I uninstalled/re-installed the program twice
    Gerald Stokes replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    July 3, 2008 at 8:57 pm
    Try installing DVDA 5.0 and see if that remedies your issue. If not, what file format did you encode your background to?
    j razz
  • Gerald Stokes
    July 4, 2008 at 12:31 am
    Jeremy,
    I rendered the generated media as Mpeg2. I believe it has something to do with the music or loop aspect. I had the menu hold and no crash. I had the menu loop with no music and it was also fine. But have the menu loop with music and Crash
