Activity Forums Apple Final Cut Pro DVD Menu Creation Tools
  • DVD Menu Creation Tools
    Posted by Cameron Hunt on August 13, 2014 at 6:41 pm
    Hey All,
    First off, I tried searching the forums for an answer to this and did not see anything relevant to my question. If I managed to overlook it, I am sorry and would appreciate a link to the thread.
    I am using FCPX 10.1.2 and am finalizing a video for a client. I need to create a gold master DVD for them to send off to the replicator, and I am hitting a wall creating the DVD title menu. The built in tools are pretty rubbish if you want to do anything custom and I haven’t been able to find a good solution.
    I basically need to be able to create a DVD with a customized menu including chapters. I need to be able to create my own background image and import it as well. I seem to be finding software that lets me do one of those things but not both. Is it possible to import an .img file to a program so the chapter markers are preserved or will I need to re-specify those and import an .mov file instead? Can you suggest what software I should use and how I should export my project from FCPX into the program?
    Feeling a bit lost and would love some advice. Thanks so much!
    Tony Rocha replied 10 years, 1 month ago 11 Members · 22 Replies
  • 22 Replies
  • Shane Ross
    August 13, 2014 at 7:08 pm
    Apple no longer thinks people need nice looking DVDs. Only DVDs that play back, and that are simple. Thus why they discontinued DVD STUDIO PRO. They think tape options are limited to DV and HDV, and that DVD authoring is old hat!
    Might need to look at third party options, like Adobe Encore. Or try to find an old copy of FCS 3, with DVD Studio Pro.
    Shane
    Little Frog Post
  • Bret Williams
    August 14, 2014 at 12:53 am
    Encore was discontinued as well. But if you have CC they still have a roundabout way of downloading it.
  • Robin S. kurz
    August 14, 2014 at 2:37 pm
    I personally haven’t used anything other than iDVD (iLife ’11) for years, should the need arise, even though I’m more than capable of working DVD SP (as a former trainer). It is THE easiest and fastest way to make an all out customised DVD at max quality, without the – IMHO – way too convoluted, overblown feature set (for what one needs 99.9% of the time) and handling of apps such as DVD SP or Encore.
    Check Ebay or an old Mac and get it for a few bucks or even for free. Set the project to “Professional Quality” and simply drag’n’drop your way to a nice looking DVD. 🙂
    BTW, if it’s to be played on a BD-player, you can use FCP X to make what I call a “Mini-BD” disk. Which is an HD version of your movie burnt onto a regular DVD-R as an AVCHD clip. Only you’re limited to around 30 mins. and playback only works on a BD-player.
  • Juanita Pretorius
    May 11, 2015 at 2:12 pm
    Hi there
    I have the same problem like yours. Which method did you use to sort it out?
    JP
  • Robin S. kurz
    May 11, 2015 at 2:36 pm
    [Juanita Pretorius] “I have the same problem like yours.”
    Why not iDVD? It will also retain any chapter markers (and poster frames) you set in FCP X btw and even make animated chapter menus if you like. All of it fully customizable.
    https://ebay.to/1IwGIJ6
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Juanita Pretorius
    May 12, 2015 at 2:38 pm
    Is iDVD allowable on OS X Yosemite V10?
  • Robin S. kurz
    May 12, 2015 at 3:05 pm
    Why shouldn’t it be?
    – RK
  • Juanita Pretorius
    May 12, 2015 at 3:23 pm
    Thank Robin, I’ll try.
  • Ken Bennett
    May 23, 2016 at 6:38 pm
    I’m in the same boat. FACT: 95% of my consumer clients want DVDs and BDs. They want something physical in their hands. Even if its a digital copy on a flash drive.
    I’m just starting in FCP X coming from Sony Vegas. Vegas came with DVDA and was easy to make customized menus with chapter stops etc. I even use Encore CS6 for more upscale DVDs and BDs. FCP X has nothing in the way of DVD creation that I would give to a client. So I too need a good solution for creating great looking DVD menus etc.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
  • Robin S. kurz
    May 23, 2016 at 6:46 pm
    Again: iDVD?
Page 1 of 3
