Activity › Forums › VEGAS Pro › DVD ISO Authored in DVD Architect Pro5 will not play in most DVD Players
  • DVD ISO Authored in DVD Architect Pro5 will not play in most DVD Players
    Posted by James Tisdale on December 23, 2010 at 10:23 pm
    I recently authored a DVD for a friend using DVD Architect5. I then made an ISO using Ultra ISO 9.3 and burned it using express burn by NHC. I have the file system set to UDF 1.02, the volume label matches the ISO name and the naming convention has all caps and no spaces, ex: TERRYS_CHRISTMAS_DVD. I’m using Sony DVD+R AccuCORE discs. I’ve made back-ups of Retail DVDs with those discs and I’ve had no trouble playing them in any stand alone player. My question is what am I missing? Is there some setting in Architect or when creating the ISO that I’m skipping? I downloaded VSO inspector and had it scan the ISO. Here is a SS from that scan:
    VSO Inspector Report
    Version: 2.1.0.4
    Created: 12/23/2010 4:22 PM
    Device: [4:0:0 – ROR 1AV4D2FO9Q 3.5Z [I] (Scsi)]
    General Information ——————————————————————–
    Vendor ………………..: ROR
    Model …………………: 1AV4D2FO9Q
    Drive Letter …………..: I:
    Firmware Version ……….: 3.5Z
    Firmware Date ………….:
    Buffer Size ……………: 128 KB
    DVD Features —————————————————————————
    Region Code ……………: None
    RPC Scheme …………….: RPC Phase II
    User Changes Left ………: 5
    Vendor Resets Left ……..: 4
    Read Features ————————————————————————–
    Reads CD-R …………….: Yes
    Reads CD-RW ……………: Yes
    Reads HD-BURN ………….: No
    Reads DVD-ROM ………….: Yes
    Reads DVD-R ……………: Yes
    Reads DVD-RW …………..: No
    Reads DVD-R Dual Layer ….: Yes
    Reads DVD+R ……………: Yes
    Reads DVD+RW …………..: Yes
    Reads DVD+R Dual Layer ….: Yes
    Reads DVD-RAM ………….: No
    Reads Blu-ray ………….: Yes
    Reads HD-DVD …………..: Yes
    Reads Multisession ……..: Yes
    Reads Mode 2 Form 1 …….: Yes
    Reads Mode 2 Form 2 …….: Yes
    Reads Fixed Packet Method 2: Yes
    Reads RW Subcodes ………: Yes
    Corrects RW Subcodes ……: Yes
    Reads PW in LeadIn ……..: No
    Reads ISRC …………….: Yes
    Reads UPC ……………..: Yes
    Reads Barcode ………….: No
    Reads CD Text ………….: Yes
    Max. Read Speed ………..: 8467 KB/s
    Write Features ————————————————————————-
    Writes CD-R ……………: No
    Writes CD-RW …………..: No
    Writes HD-BURN …………: No
    Writes DVD-R …………..: No
    Writes DVD-RW ………….: No
    Writes DVD-R Dual Layer …: No
    Writes DVD+R …………..: No
    Writes DVD+RW ………….: No
    Writes DVD+R Dual Layer …: No
    Writes DVD-RAM …………: No
    Writes Blu-ray (BD-R) …..: No
    Writes Blu-ray (BD-RE) ….: No
    Writes HD-DVD-R ………..: No
    Writes HD-DVD-RW ……….: No
    Writes HD-DVD-RAM ………: No
    Writes HD-DVD-R Dual Layer : No
    Writes HD-DVD-RW Dual Layer: No
    Supports Simulated Write ..: No
    Buffer Underrun Protection : No
    Misc Features ————————————————————————–
    Plays Audio CD …………: Yes
    Composite ……………..: Yes
    Digital Port 1 …………: No
    Digital Port 2 …………: No
    Supports CDDA Command …..: Yes
    CDDA Accurate ………….: Yes
    Supports C2 Pointers ……: Yes
    Supports Locking ……….: Yes
    Labelflash …………….: No
    LightScribe ……………: No
    Media ==================================================================================
    Physical Information ——————————————————————-
    Media Type …………….: DVD-ROM
    Media ID ………………: N/A
    Speeds ………………..: N/A
    Layers ………………..: 1
    Capacity ………………: 1.03 GB
    Sectors ……………….: 538128
    Content ——————————————————————————–
    Book Type ……………..: DVD-ROM
    Regions ……………….: 1 2 3 4 5 6 7 8
    Content Type …………..: DVD-Video
    Tracks ………………..: 1
    Sessions ………………: 1
    Bootable ………………: No
    ISO File System ————————————————————————
    Volume Label …………..: TERRYS_CHRISTMAS_DVD
    Creation Date ………….: 12/21/2010 5:23:35 AM
    Modification Date ………: 12/21/2010 5:23:35 AM
    Publisher ……………..:
    Application ……………: ULTRAISO V9.3 CD & DVD CREATOR, (C)2009 EZB SYSTEMS, INC.
    UDF File System ————————————————————————
    UDF Version ……………: 1.02
    Recording Date …………: 12/23/2010 9:23:35 PM
    Directories ……………: 3
    Files …………………: 16
    System =================================================================================
    Upper Filters ————————————————————————–
    None
    Name ………….: Afc
    Description ……: Arcsoft(R) ASPI Shell
    Company ……….: Arcsoft, Inc.
    Any help on this would be greatly appreciated. Thanks,
    James
    John Rofrano replied 15 years, 9 months ago 3 Members · 2 Replies
  • Stephen Mann
    December 23, 2010 at 10:36 pm
    I’ve been using DVDA for- what seems like -ever, and I wasn’t even aware that ISO was an option until I read your question.
    First, from your description, it sounds like you are trying to play an ISO image, which won’t work.
    Second, why don’t you just use DVDA to burn the DVD?
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    December 23, 2010 at 11:24 pm
    [James Tisdale] “I recently authored a DVD for a friend using DVD Architect5. I then made an ISO using Ultra ISO 9.3 and burned it using express burn by NHC.”
    Did the disc you made with DVD Architect work? If yes, they your problem is the program that made the ISO image.
    Why don’t you just make the ISO with DVD Architect in the first place? Choose ISO Image Writer as the device in the Make DVD window.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
