Activity Forums Avid Media Composer DVD Export
  • DVD Export
    Posted by Lumpy John on November 2, 2006 at 4:37 pm
    I’m having a problem when I export a final sequence to DVD, it seems to never be displayed in its native 16:9 format. It will stretch the image to fit a 4:3 T.V, I’m sure there’s a simple solution, but I can’t seem to figure out the problem.
    Alex Alexzander replied 19 years, 10 months ago 2 Members · 1 Reply
  • Alex Alexzander
    November 2, 2006 at 9:39 pm
    Two things to check:
    1. When you encode the sequence in your encoder, are you changing the default 4:3 properties of the encoder to 16:9?
    2. In your authoring application, are you defining the footage as 16:9?
    A little more detail on the DVD authoring application would help. If using Avid DVD, click on the Movie asset, and in its property, you should find a setting which states the aspect ratio. Make sure that is set to 16:9.
    -Alex
