Activity Forums Adobe Encore DVD DVD error 16072
  • DVD error 16072
    Posted by Phocas Kroon on December 8, 2006 at 2:22 pm
    After the burning session is almost ready I get a message DVD error 16072 end of file.
    I did a search on this forum and saw this problem in Encore version 1.0 and should be solved in 1.01. I use Encore 1.5.
    It is a DVD with 12 short movies with a menu without moving background and animated knobs.
    No error message during encoding from AVI to Mpeg. No error message during Preview.
    Any ideas?
    Phocas Kroon
    David Garrett replied 19 years, 9 months ago 2 Members · 1 Reply
  • David Garrett
    December 8, 2006 at 4:17 pm
    This is lifted from the Adobe forums.
    “I’m writing back just to let people know that Neil Wilkes was exactly right, at least for the problem I was encountering: the issue was that I needed to re-size each video/audio pair to make sure they were exactly the same duration. It did come down to a 1 FRAME difference in one of the sequences, so it is important to ZOOM ALL THE WAY IN before you start determining that if the lengths match up or not.
    I don’t know why the clips would not import at exactly the same duration as when I used Premiere to create them…very odd…nonetheless, thanks Neil for the useful tip, and thanks John for pointing me in its direction.”
