Activity › Forums › Adobe Encore DVD › DVD Encore – remote menu problem!
  • DVD Encore – remote menu problem!
    Posted by Harpervl on November 5, 2005 at 10:29 pm
    I have a project with a First Play and then 2 menus with different clips established with a video button. I actually made a diffferent project with
    just the line banner button with the clips linked to them.
    The first play clip works fine – The 1st. menu comes up and the 1st. clip has it’s select arrow highlighted. It will play. The problem is, I cannot get my DVD remote menu to activate the other buttons. None of the remote down -up – over etc., will move to any of the other buttons to select them to play.
    I have tried two seperate DVD players with the same results. If I play the DVD in my computers, they work great. When I mouse over the buttons, the select arrows work fine. I can jump between the menus just fine.
    Any ideas would be appreciated.
    V. Harper
    Harpervl replied 20 years, 11 months ago 2 Members · 2 Replies
  • Joe Bowden
    November 5, 2005 at 11:15 pm
    Check your button routing…sounds like something is off. If necessary, you may need to manually route the buttons.
  • Harpervl
    November 6, 2005 at 2:15 am
    Joe,
    Thank you for your info. I checked the routing. I had automatic
    routing on but it did nothing. I turned it off, set the routing manually and tried again to nothing happening. I then went back in
    an turned automatic routing back on, leaving the manual setting on.
    That seemed to work. I find Encore a bit odd to work with.
    Directions via manaual leave a bit to desire.
    Thanks again for the input.
    V. Harper
