Activity Forums VEGAS Pro dvd compression
  • dvd compression
    Posted by Dave on November 30, 2005 at 8:07 pm
    We have a 4 disc dvd 9 replication project that will press on dvd9.
    All discs are under 4 hours of content except for the last disc which has
    5 hours. Can we get away with compressing this last dvd at acceptable quality?
    Thanks in advance.
    Dave
    Gary Kleiner replied 20 years, 10 months ago 2 Members · 3 Replies
  • Gary Kleiner
    November 30, 2005 at 10:33 pm
    There are two unkowns here.
    1>What is “acceptable”? This depends on the use and audience of the disc.
    2>What type of content? If it is a talking head, the same compression settings will result in a smaller file size than if the content is fast action.
    For instance, on my Vegas and DVDA instructional videos, about 75% of them are screen shots which have very little change from frame to frame. For that material, I have no problem getting over two and a half hours onto one, single layer, DVD.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Dave
    December 1, 2005 at 8:50 am
    thanks gary..good points
    I suppose we are most concerned about loss that would place quality somewhere close to VHS..if it were a scale of 1-10 1=vhs 10= dvd we’d like stay in the 7-9 range for the one disc.
    Motion varies, but for the most part, medium – slow would best describe the pace, panning, zooming etc.
    WOuld a 85% compression be around the target were after?
  • Gary Kleiner
    December 1, 2005 at 3:54 pm
    You’ll just have to compress so that the files barely fit on the disc and see if the quality is acceptable to you.
    Gary Kleiner
