Activity Forums VEGAS Pro DVD burning software problem
  • George Wing
    May 6, 2007 at 9:10 pm
    What are you burning (DVD Folders, DVD IMAGE file, or other)? And what type of disc are you burning to? Have you ever burned successfully before, or is this the first time you are burning to DVD disc?
    You might try IMGBURN to burn from DVD Folders or DVD Image file.
    Regards,
    George
  • Christopher Rotter
    May 6, 2007 at 9:28 pm
    I have done DVD burning before just not with this software program. I’m burning DVD folders and I’m burning to sony media.
    I will look into that program but any more comments, suggestions would help
  • Terje A. bergesen
    May 6, 2007 at 11:04 pm
    A couple of things.
    Why are you using this program? Why not the one you used before that worked?
    Also, DVD media is always an issue. Go to videohelp dot com and read up on your media and its quality. Get DVD media identification software (downloadable from videohelp) and check it.
    Typically big-brand (Sony etc) DVDs are re-branded from another manufacturer, some times they are low quality. I use Taiyo Yuden only.
    Terje A. Bergesen : https://terje.bergesen.info/
