Activity Forums VEGAS Pro DVD burning results less than stellar
  • DVD burning results less than stellar
    Posted by Scott Knedler on January 28, 2015 at 1:56 am
    Hi, I’ve been trying to make a DVD for a friend of video I did with a Phantom 2 Vision Plus drone. The camera records at 1080p. In Vegas I have arranged some edits of the original MP4 and added some music. Trouble is when I use the burn to DVD function and watch it back the video looks horrible compared to the video renderings I have saved on the computer. Some say it has to do with the re-sampling. Strange thing is I have made other videos from hand held cameras and gopros and what not and the video looks fine when burned to DVD. I think the term is moiré, and the edges of buildings are jagged and wavy when in motion. I guess I can try to explain but I imagine theres someone out there who know exactly what I am having issues with. My questions is there anyway of fixing it or at least getting better results? Thanks.
    Mike Kujbida replied 11 years, 7 months ago 3 Members · 16 Replies
  • 16 Replies
  • Roger Bansemer
    January 28, 2015 at 12:20 pm
    Did you use the GoPro Studio to convert your footage to begin with?
    Roger Bansemer – PaintingAndTravel.com
  • Scott Knedler
    January 28, 2015 at 12:48 pm
    No Roger. My drone doesn’t have the gopro, it has the 14 mp stock camera that comes with that particular model. The original file is saved as a mp4, 1080p and 29 fps. I take it straight into Vegas and then do my edits, add music and burn a DVD right from the program. Maybe the default burning setting is my issue?
  • Scott Knedler
    January 29, 2015 at 7:24 pm
    Is there any other information needed to answer this? I have looked all over the web for people having similar problems and the answers are all over the board. Mainly I just want to be sure I have my setting correct for getting from the program to DVD. Thanks. 🙂
  • Mike Kujbida
    January 29, 2015 at 11:51 pm
    [Scott Knedler] “Maybe the default burning setting is my issue?”
    That’s a possibility.
    Keep in mind that HD has 6X the video information that SD (what a DVD will give you) does so you will experience some image degradation.
    How long is your source video?
    The only time I burn from the timeline is if I;m burning DVDs of student productions. Anything I create always gets the custom treatment using DVD Architect and custom renders from Vegas.
    My rule of thumb for burning a DVD is to use a CBR (Constant Bit Rate) of 8,000,000 for anything less than 70 min. long.
    More than that and I use a bitrate calculator to determine optimum settings.
    I always render using BEST mode as that helps with final quality.
    Audio is AC-3 at the default rate of 192.
  • Scott Knedler
    January 30, 2015 at 9:34 pm
    The video is only 2 minutes long. Just footage of a church from the air from several different angles and music behind it. I always choose “best” in the properties. Like I’ve said I have done other projects with HD footage from other sources and it comes out fine. Just video from the drone doesn’t look right on DVD. I also have given DVDA a try with the same results.
  • Mike Kujbida
    January 31, 2015 at 12:51 am
    Can you post a short clip on a file sharing site such as Dropbox so that we can try it and see what we can come up with ?
  • Scott Knedler
    January 31, 2015 at 12:49 pm
    Sure Mike. Here’s two clips. The .wmv file is how I would like the DVD to look and the .mpg file is reacting the way the DVD plays.
    https://www.flashpointe.net/temp/parkside.wmv
    https://www.flashpointe.net/temp/parkside.mpg
  • Mike Kujbida
    January 31, 2015 at 1:21 pm
    Scott, I see what you mean. Can you upload an original clip (mp4 format) for us to play with.
  • Scott Knedler
    January 31, 2015 at 3:26 pm
    Mike, I re read you initial response. My mistake, I meant the video I was burning to disc was only two minutes long. The original file is 1.5 gigs. I searched my drive for something shorter to upload. The file I found reacts in the same manner. Plays fine until converted to a .mpg to go on DVD. Here’s the link. https://www.flashpointe.net/temp/DJI00267.MP4
  • Mike Kujbida
    January 31, 2015 at 4:40 pm
    Scott, I rendered that clip out at a CBR of 8,000,000. See what you think.
    Link on Dropbox:
    https://dl.dropboxusercontent.com/u/20488019/test.mpg
