Activity Forums Apple Final Cut Pro DVD burning
  • DVD burning
    Posted by Larry Watts on December 12, 2017 at 8:53 pm
    It’s been six years since I used to author DVD’s and send them out for replication and I need to get up to speed. I used to use apples DVD Studio pro which is no longer. Before that I used Sony’s DVD architect. Here are a couple of general questions.
    Will I get better results from creating mpeg2 and AC3 files using compressor.
    Or will simply burning a DVD straight out of FCPX yield the same results?
    Right no I’m making a straight play (no menu) DVD.
    In a month I’ll need to author a DVD with menus.
    If I go the compressor route I suppose I’ll need to buy Roxio toast.
    Any suggestions as to software to create a DVD from mpeg2 files?
    Any authoring packages that I should look into?
    There are plenty of companies that still rely on giving out DVD’s.
    Thoughts?
    Larry
    Doug Metz
    replied 8 years, 9 months ago
    2 Members · 2 Replies
  • Larry Watts
    December 12, 2017 at 9:26 pm
    So I don’t waste anyones time, I went into compressor and see that I can burn a simple DVD within compressor.
    I went and read posts from a year ago about DVD authoring options: DVD Studio pro, DVD architect, Adobe Encore are almost extinct. I don’t have any of these and they can’t be easily purchased.
    Any newer news?
    Roxio toast, Sorenson squeeze?
    THX
  • Doug Metz
    December 12, 2017 at 10:30 pm
    I’ve not found anything that works quite like DVDSP, which is what I prefer.
    I have the dubious distinction of caring for an extensive client archive, and for that reason I keep an old machine running with FCS3… so any call for DVD (it still happens occasionally) has me back in the old neighborhood. My workflow started with self-contained ProRes export from FCP, then to Compressor for the streams, then into DVDSP to build it out.
    If this is something you’ll need to do more than a couple of times, you could likely talk someone on this forum into selling you a decomissioned copy for cheap.
    Doug Metz
    Anode
