Activity › Forums › VEGAS Pro › dvd burn error
  • dvd burn error
    Posted by Louren Bates on December 12, 2010 at 5:11 pm
    Hello,
    I keep getting this error when I try to burn a DVD.
    Can someone tell me what this error code means below?
    It was burning fine up until 2 days ago.
    I even uninstalled then reinstalled DVD architect.
    ‘SFMMCX’-(17)
    ”-(2)
    -‘HL-DT-ST DVD-RAM GH40L 1.04’-(1)
    Module sfmmcx.cpp Line 1819
    The command completed successfully.
    No sense.
    Status: 00000000
    Command:
    Sense: 00 00 00
    Info: 00 00 00 00
    Specific: 00 00 00
    Extra:
    Tom Pauncz replied 15 years, 9 months ago 3 Members · 2 Replies
  • Jeremy Rasnic
    December 13, 2010 at 1:33 am
    Hi. I doubt that anyone will be able to decode that here. Can you burn via other programs? Can you save the output as an ISO file and burn it via another program such as iso burner (free program)? Can you burn any other DVDA projects?
    If you need further help, you may want to contact the manufacturer of the DVD burner and/or Sony support directly.
    j razz
    https://www.jrazzcreations.com
  • Tom Pauncz
    December 13, 2010 at 3:21 pm
    Louren,
    I have seen this issue with DVDA, reported it to SONY support, beat it to death with no resolution.
    I was successfully burning DVD-R discs, but failed on trying to burn DVD+RW (re-writable). Same exact project burned fine with exact same level of DVDA and exact same DVD+RW medium on another computer – only the device was different. In my case, an LG BH10LS30 blu-ray burner was the one that failed.
    I believe it’s hardware related in the way DVDA handles certain drives. I suspect DVDA does not support some combination of hardware and medium.
    Same drive happily burned a prepared project using Nero to DVD+RW.
    Have not tried the same scenario with the newest version of DVDA.
    Cheers for now,
    Tom Pauncz
    (30WEST MEDiA GROUP)
