Activity Forums VEGAS Pro DVD Architect Pro 5.2 – Audio Media is not compliant with the disc format
  • DVD Architect Pro 5.2 – Audio Media is not compliant with the disc format
    Posted by Mark Stuart on November 25, 2011 at 9:47 pm
    Having weird random issues with .wav and .ac3 audio in a Blu-ray Pal DVD Architect Pro project. Win 7 64.
    3 movies consisting:- First play, motion menu with loop point, main menu
    In Optimise Disc, One of the 3 audio files has a green tick and is fine, the other two have a yellow exclamation mark and a Recompress is required.
    I have tried replacing the audio files with dozens of known compliant .ac3 and .wav files of stock menu audio I have used for years and previous project assets which havent required transcoding with DVDitProHD (Blu-ray) and DVDSP (DVD).
    I’ve tried all the .ac3 bit rates also 16 bit 44.1kHz and 48kHz .wav. Most files need re compressed, some are OK. I have also tried changing the project settings from PCM to AC3 and different settings. I have been unable to find a common factor to explain why some are OK and other files of the same spec are not. I wonder if its a 32 bit v’s 64 bit codec issue and related to the program creating the file.
    Has anyone found any explanation?
    Although, this is the least of my worries since the Blu-ray build is stopped by the following error:-
    At the end of rendering main movie audio – “An error occurred while preparing compilation”
    File name STREAM/00000.m2ts
    Status: TSWrapper.dll::CTSWrapper::ProcThreadMain::This program has a bug. -m_ptsOfNextGOP is empty.
    Regards
    Mark
    Mark Stuart replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
