Activity Forums VEGAS Pro DVD Architect – Button Question
  • DVD Architect – Button Question
    Posted by Phil Spitler on June 26, 2006 at 7:37 am
    I have a really simple problem in DVD-Architect v3 that I hope somebody can help with.
    I have a menu screen, with a flat white background.
    For my button I have 2 graphics, the menu option and the highlighted state.
    These 2 graphics do not have any transparency as they are both over white.
    I would love to just be able to switch between or even just add the 2nd graphic over the top of the first when the button is highlited.
    I don’t want to use transparency masks as all the buttons and the bg are on white and it will save quality if I can avoid it.
    Any ideas?
    Phil
    Phil Spitler replied 20 years, 3 months ago 3 Members · 5 Replies
  • Gary Kleiner
    June 26, 2006 at 1:55 pm
    Sorry, can’t do it.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • George Wing
    June 26, 2006 at 2:42 pm
    Are the pictures the same, or are they completely different pictures? When I say the “same”, I mean one might be “Sepia”, and the other Full Color — but the actual content/pic is the same…
    Regards,
    George
  • Phil Spitler
    June 26, 2006 at 4:44 pm
    The buttons are almost identical.
    Unselcted it is just text that says Play All
    Selected it a different color and has brackets either side so it would be [ Play All ]
    Thanks for any advice.
    Phil
  • George Wing
    June 27, 2006 at 3:16 am
    If you just want brackets, make the button link be text only, and add the brackets as WHITE text (also insert a separate text box between the brackets for the button description — like Button 1, Play All, etc…).
    Change the HIGHLIGHT STYLE to “Mask Overlay” (instead of rectangle).
    Then modify the Color Sets so that the Selected state uses a fill color with opacity to show the White brackets when you navigate to the button.
    Regards,
    George
  • Phil Spitler
    June 27, 2006 at 3:22 am
    That is what I did in the end, ideally I would have liked to change the color of the type as well as add the [ ] but using a mask overlay to change the color of the type looked a bit rough.
    Putting a red masked overlay over a greay piece of type just gave me unwanted fringing, that is why I would have loved to swap the whole button graphic and not use highlite colors.
    Thanks for your help.
    Phil
