Activity › Forums › VEGAS Pro › Dvd Architect 5.2
  • Dvd Architect 5.2
    Posted by Thayalan Paramasawam on June 18, 2012 at 1:37 pm
    good evening’
    Sir after i render my footage use sony avc/mvc…blu-ray 1920×1080 50i,16 mbps video stream….i use dvd architect 5.2 to blu ray output.i select the format avc 1920×1080 50i……but its take 3 hours to render……..pls adive me on this matter……why its take to long to render,or i set the wrong setting…….
    this is my machine spec…..
    Motherboard:ASUS M4A88T-V EVO SERIES
    Graphic Cars:ASUS HD 6770 1GB DDR5
    Ram:16GB
    Processor:AMD PHENOM(tm)IIX4 955 (3.20GHZ)
    Operating system:window 7 pro (64bit)
    thank you
    thayala paramasawam
    Nigel O’neill replied 14 years, 3 months ago 2 Members · 3 Replies
  • Nigel O’neill
    June 19, 2012 at 12:55 pm
    How long is the content you are trying to create?
    Are you using the DVDA blu-ray template in Vegas to create the render file that you then import into DVD Architect?
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Thayalan Paramasawam
    June 20, 2012 at 1:15 am
    Morning Sir,
    My footage 1s 1 hour 32 minit.i render my footage use sony avc/mvc… templates blu-ray 1920×1080 50i,16 mbps.
    thank you
    thayalan paramasawam
  • Nigel O’neill
    June 20, 2012 at 3:04 am
    You render time appears normal for the duration of the timeline. The more FX and transitions you apply, the longer it will take to render
