Activity Forums VEGAS Pro DVD Architect 5.0 – No progressive Blu ray
  • DVD Architect 5.0 – No progressive Blu ray
    Posted by Frank Manno on May 10, 2010 at 12:41 pm
    I used Vegas to render my timeline to 1920×1080 blu ray at 25fps progressive.
    In DVD architect, there is no 25fps progressive, only interlaced.
    Does anyone know a workaround?
    -Frank
    Enrique Orozco replied 16 years, 3 months ago 3 Members · 2 Replies
  • John Rofrano
    May 10, 2010 at 1:15 pm
    I used Vegas to render my timeline to 1920×1080 blu ray at 25fps progressive. In DVD architect, there is no 25fps progressive, only interlaced. Does anyone know a workaround?
    No, because Blu-ray is a standard and 1080-25p is not part of that standard. The allowable frame rates for Blu-ray are:
    1920×1080 @ 60i, 50i, & 24p (both 24.0 & 23.976)
    1280×720 @ 30p, 25p, & 24p (both 24.0 & 23.976)
    So if you want progressive you need to drop your resolution down to 1280×720 or else deliver in 1920×1080 at 24p.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Enrique Orozco
    May 10, 2010 at 11:39 pm
    ..try dropping your progressive render in the 50i template and see if it works … never try this, but 60i works without any DVDarch complaints with 30p rendered files….. at least on DVD ….
    good luck
    Enrique Orozco R.
    iDEA DigitalVideoStudio
