Activity Forums VEGAS Pro DVD Architect 3 re-rendering Q
  • DVD Architect 3 re-rendering Q
    Posted by John Gregoriades on December 3, 2006 at 3:24 pm
    I rendered a 24-minute video to NTSC with Vegas, then used DVDA to finalize it. The “rendering”-and-PREP by DVDA took 35 minutes, with best quality.
    Unfortunately, I had allowed about 3-4 minutes of black at its end (beyond the “The End” title) and wanted to trim it.
    So I used the little “slider” for “set out point” to trim it appropriately.
    Then, re-rendered using DVDA.
    This second rendering only took 4 minutes, as opposed to 35 minutes originally. (I made a DVD and it plays fine.)
    Is this normal? Is DVDA smart enough to know that it does not have to re-render most of the video? Or did I suffer some loss of quality?
    Thank you.
    John
    John Gregoriades replied 19 years, 9 months ago 2 Members · 2 Replies
  • Mike Kujbida
    December 3, 2006 at 7:05 pm
    It’s perfectly normal and doesn’t affect quality.
    DVD Architect keeps note of what was done in a “Prepare” file and, if any changes are made, it references this file and only makes the changes that are necessary.
  • John Gregoriades
    December 4, 2006 at 6:32 am
    Great, thank you , Mike.
    (Apparently it also makes modifications on the resulting PREP files, because it did not create new ones, it must have modified the old ones.)
