DVD-A Loop function,—not functioning
Posted by Dan Sherman on August 18, 2005 at 7:35 pmLoop function chosen,—-but 15 sec background video holding.
Edward Troxel replied 21 years, 1 month ago 2 Members · 3 Replies -
Edward Troxel
August 18, 2005 at 7:44 pm -
Edward Troxel
August 18, 2005 at 8:13 pmReceived your e-mail. Here’s the diagnosis:
I loaded it in DVDA 3, substituted my own media, and checked to loop
setting to confirm it did say “Loop” which it does.I then went to the “Menu Length” setting which was set to “Auto
calculate”. I changed that to Manual and put in 15 seconds as the loop
time (since the clip I added was over 15 seconds long). It did,
indeed, loop at the 15 second point.It appears the MP3 file is also part of the menu. I’m assuming the MP3
file is LONGER than the video? If yes, there’s your problem. The video
and audio MUST be the same length. Otherwise, the shorter stops until
the longer one finishes – then they BOTH loop.Two solutions:
1) Make them both the same length
2) Manually set the loop point at 15 seconds (which will cause the
audio to suddenly end).
