Activity Forums Panasonic Cameras DVCProHD Tape > Hard drive?
  • DVCProHD Tape > Hard drive?
    Posted by Kevin Decloedt on October 7, 2008 at 6:32 pm
    I have a DVCProHD tape. (shot with the varicam). I need to get this footage onto a harddrive and then into my final cut system.
    Thing is, I don’t have a deck.
    Is it possible to use the camera (which I have access to) as a deck and output the files digitally to a harddrive then to final cut?
    Noah Kadner replied 17 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Sharaf
    October 7, 2008 at 7:12 pm
    Kevin,
    The only output on the Varicam is an HD-SDI spigot, so you’d need to use a “capture card” like an AJA Kona installed in a FCP system to import it. You can convert it to PRORES or recompress it to DVCPRO100 this way. As always, the usual warnings about excessive wear on the camera’s recorder apply.
    JS
  • Ernie Santella
    October 7, 2008 at 7:41 pm
    There’s no ‘extra’ wear by playing a tape. You cannot control the Varicam’s transport by FCP, so all you can do is hit play and capture. There is no way to shuttle, just start and stop. That doesn’t cause any more wear than normal record start and stops.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • John Sharaf
    October 7, 2008 at 8:52 pm
    Ernie,
    Of course there is extra wear on the camera, at the very least you have to rewind the tape(s). I know that it might not seem significant where only one tape is involved, but it’s just a bad habit that if exploited on a long term basis will cost the camera owner extra money in maintainence.
    JS
  • Ernie Santella
    October 7, 2008 at 9:17 pm
    Well, yes and no. In my case, I just can’t afford a deck right now at $15-20K. (Not many used ones with low hours around anyway, I’ve checked) The only local rental house gets $700/day for a Panny 1400 deck. (yeah, that’s insane) As I’m not doing all that much HD yet, so, this is my best option.
    Anyway, the way I figure it is this…
    Use my camera as a transport for now (No shuttling, just rewind and play-out to FCP without stopping). I figure, sure, it puts some extra wear, but even if I have to service the transport/heads a year early, say in 3 years instead of 4. Then that would cost me approx $1.5K extra (Full replacement in parts/labor runs around $4K.) That’s still a huge savings over the investment to buy a $15-$20K deck. I could service the transport 4 or 5 times and still be way ahead in costs.
    Sure, I don’t have a deck for layoff, but I library Master video files on DVD-Rom and BluRay-Rom discs. If I have to supply clients a tape, I can take the master file to a local edit house and have them lay it off for a very cheap hourly rate.
    OK… Flame suit on!
    Ernie Santella
  • John Sharaf
    October 7, 2008 at 9:50 pm
    Ernie,
    I totally understand your position and have no intention to flame you for doing what you have to do. I own two decks, both the older 1200A and the 1400 and have to tell you that they’ve been an excellent investment and a great add-on both in production and post production, and I believe both are in profit already.
    The reality is that when ever I shoot Varicam, the client must import it into their NLE and that’s when the deck comes into play. I offer it as a preferred rate of $300/day and in LA (subject to availability) that is kind of the going rate. This way I can often “switch” a client from another requested format (usually DigiBeta).
    I’ve always considered the camera and the deck as a system, invaluable together to assure backup and workflow and then when it comes time to sell, the combination of the two assures the buyer of that same, and I can create a package price so the new owner has a complete system with which to service himself or his clients.
    JS
  • Noah Kadner
    October 8, 2008 at 5:15 pm
    I second John for the camera is not a playback deck- argument. Really not a good idea all around for workflow, wear and tear. Not too mention you’re introducing all sorts of lost timecode issues and the like by just free playing HD-SDI off the camera into a Kona. The DVCPROHD decks are a solid investment. That said, getting into a newer P2 camera without the need for an expensive deck is also not a bad call either.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
  • Ernie Santella
    October 8, 2008 at 5:19 pm
    Noah, actually I have a HDX900, not a Varicam, so there’s no lost time-code as I do get T/C out of the Firewire port vs. the HD-SDI port.
    I wish I had the funds to purchase a deck, but, as we all know, times are tight and I have to feed the dog first. haha!
    Ernie Santella
  • Noah Kadner
    October 8, 2008 at 9:05 pm
    Haw- don’t let the dog eat the tapes.
    Noah
