Activity Forums Apple Final Cut Pro Legacy DVCProHD P2 footage transfer to Apple ProRes 422 in Log&Transfer?
  • DVCProHD P2 footage transfer to Apple ProRes 422 in Log&Transfer?
    Posted by Alexandre Brandt on May 1, 2015 at 8:49 pm
    Hello all,
    I have some footage recorded on P2 cards with an HVX200. I copied the card contents and did a log and transfer test on FCP 7. It transferred the footage into DVCPRO HD but I would like to transfer to ProRes 422.
    In the log & transfer window I went to preferences selected P2 Plugin (P2 AVC-Intra) to Target format: Apple ProRes 422 but it doesn’t affect the actual transfer format. I shut down FCP and started again but doesn’t change.
    Should I trans my FCP preferences ? Maybe the P2 AVC-Intra plugin is not the one at work in this transfer ? (But all my other Source formats are selected to target to Apple ProRes 422.
    Any ideas ?
    Producer | Filmmaker
    http://www.bingo-films.com
    https://vimeo.com/channels/800406
    Shane Ross replied 11 years, 4 months ago 2 Members · 3 Replies
  • Shane Ross
    May 1, 2015 at 10:09 pm
    Sorry, DVCPRO HD P2 only comes in as DVCPRO HD. You can’t transcode upon ingest. You can convert after, by using the Media manager.
    AVCIntra P2 can be converted…but the HVX-200 doesn’t shoot AVCIntra.
    Shane
    Little Frog Post
  • Alexandre Brandt
    May 4, 2015 at 4:26 pm
    Hello Shane,
    Thanks for the info.
    Do you think there would be a benefit of going through converting to pro res 422 with the Media manager or it doesn’t serve any purpose ? For info the video will not be polished like crazy in post to look amazing… Just editing, some titles maybe made in After Effects and basic colour grading.
    Best,
    Alex
  • Shane Ross
    May 4, 2015 at 4:32 pm
    No. There will be no benefit to transcoding to ProRes. That’ll just add a layer of compression.
    Shane
    Little Frog Post
