Activity › Forums › Apple Final Cut Pro Legacy › DVCproHD footage doing weird things
  • DVCproHD footage doing weird things
    Posted by Ari Grunzeweig on August 17, 2011 at 7:15 pm
    Hi folks,
    I’m sure one of you wise people can help me out with this problem. I’ll try to give as much info as possible. I realize this is a mess.. but I need to figure it out in the next few days.
    I am editing a concert that was filmed with 3 cameras. 2 of them work fine, one is problematic. The problem is with the footage from the HVX200. I no longer have the cards, only the log and transferred footage.
    There are three clips. FCP 7.0.3 tells me the footage is:
    Clip1: DVCproHD 720p60 Frame Rate: 24
    Clip2: DVCproHD 720p60 Frame Rate: 29.97
    Clip3: DVCproHD 720p60 Frame Rate: 29.97
    With any of the three clips, audio sounds fine, but only goes through half the video track and then goes silent. Corresponding video plays very slowly.
    My other 2 cameras, are working perfectly. They are in a sequence that has a 59.94 timebase. Those were filmed with JVC hDV cams.
    I hope somebody has an idea for me!
    Thanks very much!
    Ari Grunzeweig replied 15 years, 1 month ago 2 Members · 2 Replies
  • Chris Tompkins
    August 17, 2011 at 10:43 pm
    The audio track is Shorter on all clips? Is this what you are saying?
    Chris Tompkins
    Video Atlanta LLC
  • Ari Grunzeweig
    August 18, 2011 at 12:28 am
    The audio track on all clips appears to last the same length as the video, but then waveform disappears halfway though..
